topdawg661
Once I get out of work ill flash!
nvm only when i try to restore them from my titanium back it wont work :\
Okay thanks for the advide.. just one more question , i always set my cpu to 600-728 , but one this rom i guess its lagging it because it jitters sometimes...idk what it is , i didnt mess with anything else in the performace section because i really dont know much about the tweaks and other stuff , just cpu
Jittering as in um .. when i see a picture the picture flashes like 4x then stays normal . idk but umm is the camera suppose to work yet? cause mines dont, im just saying -.-
Report: same spilt screen boot issue as Bobz and Johnnys roms (fix is the same press power button after boot is done) I've been running for a couple of hours now @600/480 interactive no rr , tb works fine to reinstall apps ( sellers I know with tdms ics it uses the SD next partion to install apps automatically just wondering if you were planning to add that feature on cna not a big issue just curious don't mind using tb) standard lock screen works just fine , that's about it for now for what I've really messed with I'll be back later with a update. Aside that yo looking real nice great work bro :thumbup::thumbup:
Sent from my VM670 using Android Central Forums
