inceyet
But remember not all phones are the same and can take that kind of abuse.... you say 844 but what's your min and what gov you on
Is it safe to change the boot animation with from toolbox?
Best song ever
Forever Given Forever You
by Evanescence
https://www.youtube.com/watch?v=naI5swhuoeI&feature=youtube_gdata_player
Yes
Sent from my shole using Tapatalk 2
Right now I'm running savagedzen at 320/864 using aokp 7/15 nightly. No fc or unusual reboots.
I partitioned my sd card but how do i move apps to the partition.. when i pressed move to sd it didnt move it to the partition.. at least i dont think it did..
Similar, 480/844 SavagedZen governor on AOKP 7/15 nightly, no FC or strange reboots. Have an older OV, before the models with new screens. Really liking ICS - was on BACKside previously, and ICS is almost all the way there (still need tethering, reliable BT, definitely feels a little fickle when messing withuh system settings) - still, amazing work tdm and company!
My favorite part is apps being able to utilize ICS animation APIs. The Flipboard app is much improved on ICS vs Gingerbread... everything involving animations feels FAST. Not as many hiccups/stuttering animations as I was experiencing with BACKside. Really love it.
SmartassV2, and I hear that the min is always (or nearly) 480, because anything lower than that, and you use the same voltage (no undervolting for this phone), and it takes even more power to get back up to minimum (click and read the post/topic I linked to). Using the performance governor was just to find out the max you can use, but I'm definitely not going to leave it on that.But remember not all phones are the same and can take that kind of abuse.... you say 844 but what's your min and what gov you on
The default save location is on your cards ext partition. Format your SD card in recovery and make sure you set you ext partition to 256mb or higher ( mine is 512mb). The higher you go the more apps you can get.
Does it HAVE to be formatted by the recovery or could I just use something like a partition editor on my computer?
