nitestalkr
Might wanna wipe system too.
Actually, its not necessary, I used CM9 to disable 270degree rotation, so it would stick in AOKP, I didn't wipe the system partition, and still no issues... its almost like a ghetto hybrid CM9 AOKP quattrimus. Whatever can be changed in CM9 and not AOKP, I make the changes in CM9, wipe cache and dalvik, then flash AOKP and gapps, and the settings stick, with no issues. I think i should have shared this earlier.
And since its basically the same ROM, just different mods, AOKP would overwrite anything that would screw things up in the system partition. Its kinda like flashing an update, as long as its the same OS or ROM, you only need to wipe cache and dalvik cache.
sent from my un-dead sammich.
