strabo231
Anyone found a good work around for video play back
MX player from the market
Try wiping cache in recovery. I noticed I used to get that error before I added an sdext and took care of the space issues.
I've done this. Multiple times. When I go into root explorder it says sdcard and sd-ext although I never made an ext partition. Could that be the problem?
Using it. Says it can't play a video I recorded.
Did you grab the codec pack too? Bubbleupnp works too.
Are you talking about that armv6 apk
Yup
Yeah I got that...so this is my story I recorded a video, emailed it, didn't need it at the moment, now need it back and re-downloaded it from my sent folder and it won't play. Any idea?
Most of us have gone that route and the problems went away. Top link in my signature
a CLEAN flash ( i usually do it dirty tho...i mean come on) fixed the power button issue.
my wi-fi and signal strength icons are still grey tho...and thats not very sexy.
I have 2 problems though.
1. The computer I am using does not have administrator privileges.
2. I do not have a MicroSD adapter for the PC.
I have a question (and I apologize if this has been answered in the past), I was wondering...can I flash the nightlies right on top of the Beta ROM? Or does that require reflashing? And is there some sort of changelog that goes with these? What's new in the July 31st nightly? Any fixes?
How low or high are your bars and when your connected do u c the arrows
