It's under 1mb larger to support 3 phones. The same kernel is used for all models, and the unique files per model are binary diffs.
The second I overclocked it froze.
Same. But i over clock to 864 no probes on any CM7 GB roms. Weird.
Lol, you quoted my post 200+ pages back xD!
It has to do with the kernel, I believe.
I don't know much about ICS
I believe there are no ICS kernels for us yet.
How long for aosp ? =[
You are correct my good sir, the one were currently using is a modified gb kernel. Tdm is hard at work on a 3.0 ics kernel for us though
Sent from my A.C.R. Zombified Quattrimized AOKP OV.
Ever try to port AOKP using CM9 as a base? It not only doesn't work, it's actually pretty funny!
sent from the hip.
what are you looking for?? Isnt the unicorn their trademark? Click to view quoted image
Would you prefer farting unicorns??
did anyone find a fix for the "screen turning off" thing? Can't keep pulling the battery off.
Overclocked 480/768.
Is there any way to fix the HQ on YouTube videos?
Sent from my LG-VM670 using Xparent ICS Blue Tapatalk 2
What do you mean by "pretty funny"? Is there a clever error message or something?
