[ROM][BETA] Quattrimus ICS
cole2kb
Retired Moderator
Apr 7, 2011
2,503
547
There isn't much detail on the remaining bugs (for LS670). Would somebody please tell me how bad they are?
1) HQ video. Can I watch SD YouTube videos no problem?
2) Deep sleep bug/power drain. How bad is it? How much less battery life relative to GB ROMs?
3) Clock lag. Would my phone likely becom unreliable as a timepiece? As an alarm clock?
4) Random reboots. Roughly how frequent (on an LS670)?
A note on the alarm clock -- I haven't had any issues with it missing my alarms, even if the time itself doesn't update. I don't have ClockSync installed, but I do not use the built-in alarm clock, I use Alarm Clock Plus from the Play store. (Awesome app, btw.)
Tasker should be able to do that, though it's not a free app...
The phone should do this automatically, but OP's question was vague.
Do you want 3G to turn -off- or just the phone to switch to Wi-Fi? As long as you have Wi-Fi turned on, your phone should connect automatically to a known network within range.
Reactions: RazzMaTazz
sellers86
1,837
617
Alarm clock works fine without clocksync guys. The clock lag is in the notification bar and lock screen. Don't believe me? Download clocksync and check the system time before you do anything else with it.
droiddekka
166
24
sometimes it does and sometimes it doesnt. i leave wifi and mobile data on all the time. until it hiccups, and then i usually toggle wifi off/on and it works again...just wondering if that's been ironed out at all.
i'll live with it i guess.
terthii
226
33
Without ClockSync, my system time can be off by up to fifteen minutes.
brotherswing
555
167
For the record, I don't use clocksync and my phone is my alarm clock. The system is keeping accurate time, it just doesn't display the accurate time. That is until you rotate the screen. Then it updates correctly. I don't feel the need to run an extra app just to save me the effort of rotating my phone. My alarm has never failed me (on this rom, anyway) and I haven't been late for work, so I guess to me it isn't a problem. :rolleyes:
sent from here to there...
Reactions: purpulehaze
bhasden
Active member
Jul 24, 2011
39
15
I have the same issue. If I leave my phone sitting around for a couple of house the wifi connection gets dropped and doesn't reconnect when I wake it back up. A simple toggle of the wifi from the notification bar gets it to reconnect.
drew_t
92
5
Rotation fixes the status bar time display, but the "Ice Cream Sandwich Clock" widget I have on my home screen doesn't pick up the correction. Only the clock sync app (which I have set to sync every 15 minutes since every 30 seconds seems excessive) works on it.
drew_t
92
5
I had that issue when I was on Backside, but since changing to Quattrimus CM9, it hasn't happened at all.
brotherswing
555
167
Ah...I use Fancy Widgets, that seems to stay in closer sync.
dingermtb
203
26
Been getting a new market error now. When trying to download free apps, i get "error processing purchase (DF-BPA-09)" That's for free apps, not paid apps. Anybody else getting this? Also, tried clearing market cache and data, then in recovery, cleared cache and dalvik cache.
Sent from my Zombie ICS-VM670 using Xparent Red Tapatalk 2
brotherswing
555
167
I got that. Clear the data for Google Services Framework. You might need to reflash gapps afterwards. When it happened to me (yesterday) I got it fixed, but the calendar went missing.
Reactions: dingermtb
dumpsterrentals38
