The ics kernel just got a new boost. I was able to get a framebuffer console on my spectrum, which has a similar graphics system. If I can get that working on the ov, that would make kernel work sooooo much easier.
I'm getting the insufficient space error again. I have an SD Partition. Settings is telling me I have 69MB free (No jokes ) When I try to install or update apps that I know are less then that, it gives me an insufficient space error. I haven't actually been able to update google maps since they changed their icon. However, some apps will update. it's just a stubborn few that won't. It also happens with apps not in the play store, such as CM themes from XDA. I wiped cache and dalvik, no go. I have no 01mdalvik file in /system/etc/init.d, so I know that's not the problem. Anyone know a good solid fix?
...and in AROUND THE NET...
AOKP JB Build 3 built for P500. Looks like it's portin' time:
[UNOFFICIAL] [ROM] [BETA] [JB] Android Open Kang Project - LG-P500 - Build #3 (BETA1) - xda-developers
I just cleared app data and cache from the manage apps screen...and am now updating left and right.
Cleared cache+dalvik, market data+cache+uninstall updates, still no luck. I am able to install certain apps but not others. Gr.
Tapatalk? from my Optimus V
Hope this does get ported aokp jb on nexus s is amazing.... *sigh* too bad optimus elite doesn't even have ice
Oh.. Anyone able to install bad piggies? I tried to side load it but the native libs didn't get installed.
Yeah cm10 and aokp41 are in the works. I plan to get rid of that insufficient space error by using the sdext for more stuff.
Are the apps that you're able to install smaller than the ones you can't install?
Heads up for anyone when cares: Nova Launcher Prime is only .25? in the Play store today. Make the phone feel 100x faster when using it with "Nova" transition speeds, and has JB style animations and features.
