[GUIDE] Unbrick/Upgrade Optimus V [EASY] [KDZ]
G.Monroy.92
4
That didnt work. I am still having the same issue. It goes through it all but when the phone resets, it just resets into the recovery.
And the sd card it is still not mounting.
anon631962
9
I'm having an issue like G.Monroy.92
Steps 1-8: Okay
Step 9: Upgrade Error / WParam: 100 / LParam: 84
Step 10: Okay
Step 11: "reindeer battery" = "reinsert battery"?
Step 12: Okay
Then it ends up at:
Phone: CWM-based Recovery v4.0.1.5
KDZ_FW_UPD: Step : Phone Reset(DLL Cmd)
On phone I "wipe data/factory reset" and "reboot system now" and I get to:
KDZ_FW_UPD: Upgrade Error / WParam: 100 / LParam: 92
And phone keeps rebooting into recovery.
I have done the steps 10+ times both with and without the battery and either the above happens or it gets stuck on repeating "Step : Flash Burning(SDRAM to FLASH)".
I updated to VM670ZV9 without thinking about waiting for it to be road tested then rooted as per (http://forums.androidcentral.com/op...-security-update-now-rooted-thanks-jcase.html). I wanted to get rid of crumbs of things I installed/uninstalled and without thinking (once again) I did the Menu / Settings / Privacy / Factory Data Reset. Any help you can give would be greatly appreciated, I can't afford a new phone and losing my grandfathered plan! Any other information you need?
sammyz
825
190
I don't know why it shows my response before your question, but yes, it bootloops into the CWM-based recovery.
Did you try to start from emergency mode??? That would help if you haven't tried already...
Sent from my LG-LW690 using Tapatalk 2
anon631962
9
Yeah, as per the OP Unbrick Directions. I followed those directions many times (and any adjustments discussed in the comments since OP) and I just keep getting bootloop into CWM-based Recovery.
anon631962
9
I think your battery is dead, anyways try this: http://androidforums.com/showthread.php?p=2904142 will fix your boot loop...
Battery seems alright, Tried that, but phone outputs as follows:
-- Installing: /sdcard/flash_image.zip
Finding update package...
Opening update package...
Installing update...
Installation aborted.
In the Root instructions followed previously (http://forums.androidcentral.com/op...-security-update-now-rooted-thanks-jcase.html), it talks about "Prevent Recovery Re-Write". Is there something I need to do to enable the Xionia installation?
sammyz
825
190
Flash the flashable xionia zip (one may not exist, if that's the case I'll make one) then hit reboot recovery.
anon631962
9
OMG! I decided to try the directions in the original thread http://forums.androidcentral.com/lg...covery-xionia-clockwork-cwma-v1-2518-6-a.html (using adb shell) instead of the one you gave me http://androidforums.com/optimus-v-...tory-reset-your-rooted-phone.html#post2904142 (using phone's recovery screen) and it rebooted right into the phone! Thank you so much!
Now, when I want to do a factory reset (getting the phone back to original everything), do you think it would be best to apply the VM Update Package http://www.virginmobileusa.com/resources/update.zip again, then root as per http://forums.androidcentral.com/op...-security-update-now-rooted-thanks-jcase.html? Or is there a better method?
strabo231
497
96
You don't have to apply that update. It's actually been recommended by virgin not to now because a lot of people have reported it killing their data speeds. I applied it on mine and ended up going back to zv5 I had on it originally...but if you wanted to try it, then you need to apply the update first, then root. Otherwise you can just skip it and go ahead and root.
anon631962
9
Then I should use http://forums.androidcentral.com/op...-how-simplified-root-recovery-custom-rom.html to root and will the custom recovery factory reset restore everything to factory (except rooted)? Or should I use How to restore your Optimus V to almost original condition then root again through the first link? Or is there a better method to restore to factory? I'm a little OCD and like to be able to start from scratch regularly. Thanks!
strabo231
497
96
If you are wanting to root and install a custom rom, and you are not going to upgrade to zv9, all you need to do is root and flash the recovery. If you truly restore your phone to stock that is also going to mean putting a stock recovery back on the phone which will also unroot. Unless you don't want root or you don't want a custom rom, restoring to factory first is just causing you to do everything twice, and there is really no benefit to that, and its also unnecessary. So basically just follow that first guide and then put whatever rom you want on the phone. Just skip the part about trying to restore stock...like I said, it is not a necessary step, and its kind of a waste of time in this instance. I don't know which baseband you have on the phone now, but gingerbreak May not work, in which case you will need a pc and superoneclick.
anon631962
9
Baseband Version: VM670ZV5_60401001
I don't necessarily care about a custom Recovery or ROM (unless there's one that provides on-the-fly encryption of the SD Card), I just want to Root to be able to get rid of bloatware I won't be using and save space on the internal storage using Link2SD. First time, I Rooted via http://forums.androidcentral.com/optimus-v-rooting-roms-hacks/57485-how-root-lg-optimus-v.html - is that better for me to use? I'm looking for a safe, not too complex, way to Root, Restore (including stock stuff I may want to use again), and repeat as my OCD deems necessary. Thanks again!
strabo231
497
96
No, you need Gingerbreak. You are running ZV5. Superoneclick will only work with ZV4. If you want a stock rom, I would actually suggest finding the third stock version. It's exactly what came with the phone, but minus all the bloatware and other unnecessary items. That's probably your best bet. That way you can be sure you aren't removing something that needs to be on the phone, as there are s few Google apps that need to stay in order for android to function properly. Actually I'd also suggest that you go ahead and apply a custom recovery as well...makes backup and restore a little easier, and also will save you some steps later if you change your mind about a rom. Just makes various installations easier in general.
anon631962
9
So I should Root and install custom Recovery as per http://forums.androidcentral.com/op...-how-simplified-root-recovery-custom-rom.html, right? Can you link me to the ROM you're talking about? I've been unable to find it.
strabo231
497
96
Yeah for the recovery you really can't get any easier than that. The rom I'll dig up for you. Might take a few, but I'll get it
- - - Updated - - -
Here is the link where you'll find the stock modified froyo rom. http://androidforums.com/optimus-v-all-things-root/268356-rom-stock-virgin.html
strabo231
497
96
kdz fw updater says my phone was not found in the log bog
Kdz? What are you using that for exactly? Since you aren't doing an upgrade or a restoration, you don't need it. Do you have a custom recovery? If you don't just get one on the phone before you worry about the rom and you won't even need to mess anything else. You'll be able to install the rom using the recovery
Non
