YoshinJaa
Just for documenting here, I didn't follow clodfelterac's instructions. I basically just followed the devs instructions at XDA in that all I did was flash the script.
so basically my steps were:
1) wipe data, cache, sd-ext, dalvik
2) partition sd-card (2gb sd-ext, 0 swap)
3) mount sdcard
4) adb push bobz rom, gapps, a2sd++ scripts
5) flashed Bobz rom
6) flashed gapps
7) flashed a2sd++
8) reboot
I tried just flashing a clean wipe with the a2sd++ script and it didnt stick. I ended up removing the scripts in clodfelterac's post (post #202) and adding the 40a2sd script manually to the rom instead and it now sticks very well. Thanks for the help
