I just got a new Class 10 16 MicroSD card from Sandisk so I figured now would be a good time to upgrade from Quattrimus to Cold as Ice(because I've heard so many good things about it).
So I know that Quattrimus had a special thing that you had to do with the memory card (which I did long ago). But I don't know what I have to do for Cold as Ice.
I'm not worried about backing anything up because right now I just want a fresh start.
So first I want to use a link2sd type script so how should I format my new memory card? Does the Cold As Ice ROM script automatically move them or what would I need to do?
Then I already have the Latest Cold as Ice ROM, Gaps, and Virgin mobile fix. So I could just flash them after I get the memory card setup right?
And then I think I'd be good to go.
So would anyone help me out with these questions?
Thanks, Ray
Thanks, Ray
