scoutconnor
Which versions are the home and menu buttons in their correct positions?
Edit: or how do I change them back manually?
Which rom did you start with and which kernel did you flash?
013 switches keys with ASOP rom
The anykernel version or the bootimg version?
Sorry 013 anykernel switches keys on ASOP, 013 bootimg won't even boot
native tethering works in the newest version of aosp's cm7, haven't tested the bluetooth or headset yetstock rom. Kernel version .08
i would install another rom but i don't want to have to esso all of my apps and settings (i really wantcm7 but i need native tethering and access to bluetooth and the headset jack)
edit: Xionia .08 kernel.
key 226 HEADSETHOOK WAKE
key 116 POWER WAKE
key 107 ENDCALL WAKE_DROPPED
These are the only buttons I see in the handset file to edit buttons:
There is nothing else... how can I swap the Home and Menu button? I've tried ButtonRemapper, but it just gives me this:
key 230 HOME WAKE_DROPPED
key 229 MENU WAKE_DROPPED
key 59 MENU WAKE_DROPPED
key 139 HOME WAKE_DROPPED
key 102 MENU WAKE_DROPPED
What governor did you have it set to? "Conservative" can cause problems on all kernels. You should set it to interactive, or better yet, you should try not underclocking. It only wastes battery: http://forum.androidcentral.com/opt...attery-drain-optimization-tests-part-2-a.html
Thanks for testing it though and reporting back!
