I wonder why the regular Note 10 has a toggle to turn fast wireless charging on and off and the Note 10+ does not?
Could also be one of those things a pesky carrier removed.
Have you actually connected it to a fast wireless charger?I wonder why the regular Note 10 has a toggle to turn fast wireless charging on and off and the Note 10+ does not?
I sort of doubt it.... It's possible the OP hasn't connected it to a fast wireless charger which triggers that toggle to appear.Ohhhh...True. Didn't think of that.
Would you actually use it often?I wish they would put a toggle in the drop down notification box to turn fast charging on or off.
I would. I don't have fast wireless charging turned on. Most the time I'm wireless charging over night so no need for it, but occasionally I need to do it other times and it would be nice to have a quick way to turn it on or off as needed, it's kind of a pain the way it is now.Would you actually use it often?
I know that's what I hear all the time, but I'm old school yet, lol. I always hear heat is bad for batteries and fast charging usually causes more heat so I just don't use it since it's all night charging and there's no hurry. I suppose I should just change my old school thinking. LolFast charging doesn't shorten the battery life or cause any other problems, so there's really no need to turn it off. If the phone is sitting on the charger all night, it will charge to 100%, stop charging and, if during the night it drains down past the trigger point (probably around 97% or 98%) it will top off again, the same as with regular charging. (Fast charging stops at around 70% anyway, then you're back to normal charging, so the battery doesn't overheat.)
If that was true why would Samsung turn it off by default and why give the option to turn it on and off at all?
Wireless fast charging option to turn on or off does not appear in options until you connect it to a fast wireless charger.Samsung doesn't turn it off by default.
It doesn't appear till you connect a wireless fast chargerSamsung doesn't turn it off by default.
