Unsure if this has been posted but I'm having difficulty even with a strong wifi connection downloading pictures. It just spins and spins. I'm using the stock app. Anyway to fix this. Thanks! Yes mobile data is on
Reset network in settings,>general management >reset >reset networkUpdate when I turn my wifi off they come through. I have fiber optic so this weird. I'm texting myself BTW
Yes known issue on attYeah, I recall this being a somewhat common issue with AT&T's wi-fi calling.
Yes...he mentioned AT&T in another postAre you on AT&T by chance??
I had same issue where sometimes texts wouldn't load... showing separate from the group chat... click on the download and it spins forever until it finally decides to come through. And in my case I think it was AT&T WIFI CALLLING enabled that caused the issue.
Because when enabled, it will push calls and texts through WIFI but I turn off wifi and it goes through... turn off AT&T WIFI CALLING and it hasn't happened since.
I turned it on for the heck of it but after I thought about it... I never have an issue with calling or signal issue for calling or text with AT&T so don't need it.
I've been on the unlocked models for awhile so no WiFi calling there lol but yeah been through troubleshooting quite few threads on that issue.Interesting... never knew. I think over the years I'd enable/disable it when playing with setups and on the N20U must have decided to do it and when I had the issue I just thought maybe that could cause it and guess I got lucky. Never noticed any call performance with wifi calling on anyways.
