Please help, galaxy note 3 major issue!
A
AC Question
Hi all,
I have a samsung galaxy note 3, I've had it for a year now with no issues. Today it decided to close my apps and had a little hissy fit so I restarted it, it took about a good 5-10 minutes to turn on which I thought was odd seeing as it always starts quickly, when it finally turned on all I could see was a blank screen with only the notification tab at the top of the screen. I restarted again and again and it is still showing the same thing.
I contacted Samsung and went through the 'safe mode' startup and all that jazz but it wouldn't even bring up safe mode.
I took it in store where I bought it and they suggest sending it away but I may lose all my data which I really don't want to happen so I then took it to a phone repair store where the phone guy said he hadn't seen this issue before, he took apart the phone and looked under a microscope and said there was no water damage etc and this has left him stumped.
Has anyone experienced this before? Or know how I can save my data before sending the phone away? I tried to use a program called Smart Switch but it says the phone is locked so I cannot access anything using that. USB connection also brings up nothing, my pc picks up the phone but says there is nothing on it.
I can access S Finder in the notification menu and see that my data is still all on the device but it wont let me get into anything, if I click on an image and try to share it the screen goes blank again.
Pleassseeee help :(
xxnattx
Mainly photo's but as I said, upon connecting to my computer it isn't showing any folders on my phone so I'm not able to transfer them.
candicet123
4
Hmm this seems to be a common problem which is happening at the same time for people...
I've wiped the cache thing and used safe mode and still no change. Like you, I also would like to get photos off my phone before i factory reset it
Androiduser91
11
It happened to me as well.
After I restarted my samsung note3 it wouldn't start as usual.
It took a while to start and when it finally started all i could see was notification bar. The screen was blank. I tried to get all my data using usb but it wouldn't connect as my device uses a pattern lock which is restricting to open my folders.
Is there a way we can get the data and factory reset the device.
Or can we remove the pattern lock using adb but again we will have to enable usb debugging which is not possible.
Androiduser91
11
doesn't work that way. Still the same issue.
I can factory reset the device but the challenge here is to backup the internal data before reset.
Keeping in mind that the phone has a lock which will restrict access to connect to a pc using usb.
chanchan05
Q&A Team
Nov 22, 2014
8,519
Have you tried Samsung SideSync to see if you can see the screen on a PC? It works even if the phone is locked. You need a way to push the app to the phone though. If the phone is connected to internet.
Androiduser91
11
Well I could try and connect it to the internet but how will I get the app into the device and get it installed?
Even if I could somehow get the app into my device and share the screen, don't you think it's still going to display the same thing on my PC. I mean all we are doing is sharing the screen on a PC which will eventually display whatever is being display on the device. That being said we would only see the notification bar and black screen again.
chanchan05
Q&A Team
Nov 22, 2014
8,519
You can access the Play Store on a PC browser, and select your device and press install. It will autodownload on your device.
Well it would show if it's hardware error if it shows up on the PC screen. Have you tried just tracing the pattern on your screen despite not seeing it?
Androiduser91
11
I'll try using side sync now.
I already tried tracing the pattern but whenever I press S finder right after pressing the settings logo from notification bar I'm able to see the settings menu for a second till the S finder opens.
I suspect that there is something wrong with the user interface. The settings menu opened without unlocking the pattern From the PC i can still see that the device is still locked.
I'm using samsung Kies3 to try and backup the data but still shows that the device is locked.
trustse7en
7
Hi,
today I experienced the same issue. Everything was working fine until I restarted my Note 3. It took much longer than usual (first I thought it was stuck at Samsung logo) and then it booted to black screen with working notification bar. The fastest solution would be probably to wipe the phone but I also need the data from the phone (best a full backup) and I also have a lock screen (PIN).
Situation is quite unusual. I tried all sugestions that could be found on the internet at the moment and nothing helps (including this thread). The facts I can share with You are:
- through notification bar I can run S Finder and through that I can search through the phone content
- thanks to above it is possible to run SOME of the apps (some like 'Contacts' are starting and running in the background but You cannot use them because of the black screen coming straight away and some apps are missing, like they got deleted somehow). By that I can run "My Files", "Gallery" and "S Note" so it is possible to backup atleast media and notes I suppose. I will try to do that tomorrow when I get an SD card.
- Home button is not working
- Google Play is not working
- Wifi works but SIM card doesn't
- When the phone finishes booting and I go to S Finder usually I get many pop up messages saying that some app has stopped working (for example "Contacts memory app", "Settings app" etc.)
- When I switch beetwen S Finder and "My files" there is a flash of other apps working in the background or the start screen itself (so it is there) for just a milisecond - it depends if I tried already to open any app through S Finder or if is it a fresh boot
- I tried to type the PIN on this black screen but there is totally no reaction
Hopefully someone will find a solution for that because I see that more and more people is experiencing this issue during the last few days.
Thanks for any suggestions!
Androiduser91
11
Well Good news guys.
I found a way to get the phone working again.
Without using any application.
All I did was play around with my device.
This might seem funny but it works 100% and right now I'm using kies3 to backup from data.
DO NOT GET FRUSTRATED AND DON'T DO FACTORY RESET.
Just follow my instructions:
-Power off your device
-Switch it back on
-Samsung logo will be displayed for a while and then after few minutes you will be able to see the notification bar and stuff like network bar wifi signal battery logo time etc.
-along with the notification bar you will see a black screen and there won't be any user interface.
-here is step you need to follow to unlock your device if you have any lock type(patter,pin,etc)
-pull down the notification bar and you will notice s finder.
-search for the word "pattern" in s finder
- then under settings>lock screen> screen lock tab you will see "Pattern" displayed and under patter "medium security"
- go ahead and choose that.
Note: After you choose that option the screen will be black again but dont worry.
-once again pull down the notification bar and choose s finder lets name this step as "pulldown" to make is easier as we go down
-so after "pulldown" choose s finder and before the s finder opens you will get a second or 2 to see the pattern till the s finder application window opens.
-go ahead and press back button next to the home key(ensure that while pressing back button we only close the s finder window)
-as soon as the s finder window is closed try and draw your pattern and if you are successful in drawing your pattern it will take you to the next option to select the lock type(but to make sure you are in that menu you need to again "pulldown" and select s finder, before s finder window opens you will notice the select screen lock options as shown below.
SWIPE
SIGNATURE
PATTERN
PIN
PASSWORD
Go ahead and choose swipe and VOILA there you are you can now connect your phone to your pc and backup your data.
Hopefully the above helps.
For any queries you can mail me
[email address redacted by Mod]
trustse7en
7
I managed to get to the screen lock option screen (though with PIN it seemed impossible at the beginning). But I am unable to click the "Swipe" option. I understand that I have to click it during this one second between black screen and S Finder, correct?
Androiduser91
11
Yes, whenever you exit from S finder try to choose swipe. Make sure you are choosing the right option, imagine the position of the swipe option and choose it.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,602
4,751
113
First, thanks for the detailed solution! Hopefully it can help others. Second, I redacted your email address--we ask that members not post email addresses or other identifying information, primarily for your own privacy and safety. You can ask people to send you a PM on this forum, if you'd like.:)
tress
