When I connect my Note 4 to my 32 bit Windows 7 PC, it is not recognised in Windows Explorer. In Windows Device Manager it is listed, but with the yellow warning and question mark. By Updating the Device Software the correct device driver is installed and it is then listed in Windows Explorer. If I disconnect the phone and go into Windows Explorer once more the phone is again unlisted and I have to repeat the Device Manager process to get it recognised. At no time is the phone ever recognised by Kies 3. Thus far I have uninstalled Kies 3 and re-installed it. I have connected the phone to the PC from different USB sockets (I have not used a hub) and have used 2 different leads. I should also point out that it is connected as a Media Device MTP and has USB debugging ticked under Developer Options.
My concerns are why I have to update the software each time after disconnecting and why it is not recognised by Kies 3. I feel the two issues are connected, but I have run out of ideas to try to resolve these issues. Any help appreciated.
