Still working for me. I listened to 5 consecutive albums last night with the stock player and no skips. I thought it did for a minute but it turned out somebody had just sent a message and this caused the volume to lower a bit. 3 hours of Pandora the day before with no skips. So far the timer doesn't seem to cause too much drain and not really a nuisance at all running a bit behind the scenes. Also, I like the idea of being able to easily control how long it runs. If I set it for 5 hours, then it will do its 5 hours and stop instead of running forever until I kill it. Just have to remember to turn it back on when listening to tunes...my phone skips about every 30-40 seconds without it so that is an easy reminder lol.
I keep forgetting to check the battery usage because I keep plugging my phone in at night and forget about it until the next day.
Galaxy 5 4.4 (downgraded from 5.0 because I loathe it and it also had no effect on the skipping)
Sprint
LG Tone Infinum BT earbuds
Players tried: Stock player, Pandora. Will try Google and Amazon music next.
UPDATE:
OK, so now this is getting weird. After using the timer workaround very, very heavy for the past 3 days with no glitches ( I was using headphones and listening intently for skips so I'm positive), I decided to turn the timer off after it had ran for a couple of hours on day 3 and see what happened. Guess what? NO SKIPS. I tried everything, running stock player and Pandora to get a skip. I was practically begging for a skip, but then I played 2 or so more hours after turning the timer off and nothing. No skips whatsoever. I'm a guy that has had a really bad case from the beginning, like a skip every 30-40 seconds per song. But now I was getting nothing, no skips after turning the timer off and screen was still off.
Then I made the apparent mistake of rebooting the phone, re-paired with my headset and the skips were back to normal with the screen off.... a skip every 30-40 seconds.
I go back to the "screen on" method, setting my display time out to 10 minutes and now we are back to no skipping while the screen is on.
So now I decide to stop the music momentarily and set up the timer again....stop music, screen timeout back to 1 minute, timer back on, music on.
Skipping is back to normal with the screen off and the timer running. I have never previously made it 3 minutes much less the 3 days and I thoroughly enjoyed this workaround I thought I had found. I was happy enough I was just getting ready to take advantage of a deal on Amazon and get another pair of my LG Infinims for 89 dollars (a great price on these) and then crash, boom.
Depressing.
All I can think of at this point is clearing the main cache partition, the Bluetooth cache, then running the timer again and seeing what happens.
Update #2:
Things seem better using the timer after the reboot if I let the screen time out naturally instead of hitting the power/lock button as my hands have been taught to do over the years. Naturally and with timer progressively gets better as more tracks play. Still not perfect as it had been the past three days but I can get several songs to play without a skip until not really very noticeable (5-20 minutes clear play early on the post-reboot experiment so far) after the first couple or three songs have a little skipping so long as I don't hit the lock button to turn the screen off. Still better than the every 30-40 second cut outs. The last time wasn't just luck...I just know it, I just don't know why my reboot killed it?
Update #3
Screw it. This is still irritating me. Update #2 information isn't as solid as I first thought it was. It varies. Sorry about that. And then I shouldn't have to spend my hours trying all this crap when it is probably a simple patch with the right update if a certain company or two would just do it. I'm getting a new phone. I'm first going to try and push the 1 year warranty at the Sprint store and hope for a straight up exchange for a brand new GS5 that might not have a problem (I'll have it running 4.4.4 by the end of the day). I LOVE the GS5 with KitKat other than this little bug, dammit. I don't want to quit the phone but I'm not afraid to switch carriers. If they try and force me to pay 200 for a refurb, then I will tell them to stick it and buy out the rest of my contract.
