I have a Samsung Note 4 I'm using the stock message App. What is the best way to send multiple pictures. I can only attach 2 maybe 3 at one time. Thanks for your help.
Do you go in to the messaging app to send them or do you go in to Gallery and select the ones you want to send and send them that way?
I go thru the text app. But let me try that. Thanks I will report back thanks
The problem, unfortunately, is a carrier limit on MMS. I really wish they would do away with the annoying MMS crap and just let us send pics and vids using data!!! Which carrier are you on?
I agree
If you root the phone you can use Wanam Xposed to modify the MMS limit.
AT&T = locked bootloader w/ no root in sight and even if there was root for 4.4.4, AT&T's devious ways of automatically downloading and installing 5.0.1 will cancel that root right out.
*Edit*
I keep forgetting this isn't only an AT&T Note 4 message board so OP may have another carrier. Please disregard.
If you can't send any pics at all I wound contact your carrier. There is probably a setting that needs to be adjusted on your account.What is the "MMS" crap that you are talking about? I still can't send any pictures through this stupid device.....
