Options for wireless/QI charging with THICK case....
Quickerthanu
5
Hi All,
First post here and did a search but couldn't quite nail down what to get.
My question is what pad and battery receiver will be best for my SUPcase Unicorn Beetle Pro case? Basically looking for a pad/receiver combo that works thru thick cases.
I purchased the factory Samsung pad, and generic battery receiver but it doesn't work with the case on.
Thanks all for the time and opinions!!
IAmSixNine
3,157
72
If your using a thick case you probably wont find any pad / receiver that work well.
There are limitations to the distance the pad and receiver can be and the thicker the case the farther apart the two are. Maybe in a year or two as the technology progresses the distance gap will grow.
cloudsofmana
