Note 5 Battery life thread
kj11
2,129
46
48
Does anyone use power save mode? I do most of the day and it really helps me. Plus, my brightness is usually turned way down because the screen is so bright. I only turn the brightness on when I'm outside in the sun.
Note in my house!
I do not. Never had the need, but I imagine some day if I'm stranded on a deserted island it could come in handy.
crf450r420
Active member
Sep 12, 2015
37
So the first app I've found to drain a lot of my battery even when I don't use it all day is Tapatalk. Went from a 36 to 38 hour battery to a 24 hour battery without opening the app. So yesterday I disabled and battery was good again. Activated it today and it is draining again. I'm going to try and set alarms with Tasker for every 10 percent battery so I can screen capture both ways at the same points.
Venom0642
2,361
340
83
I use Tapatalk and it never drains my battery at all, what version Tapatalk you using cause latest Tapatalk is v5.2.10 link: https://www.apkmirror.com/apk/tapatalk-inc/tapatalk/tapatalk-5-2-10-android-apk-download/
Venom0642
2,361
340
83
Again, when not using. Didn't even open the app. I'm using the latest from play store like most people do.
AT&T Note 5 i use gplus all day and Tapatalk plus web browsing and do lots of texting few phone calls and watch YouTube off and on and i get 1 day 12 hrs of battery life, plus sot for over a day 5hrs, if i was to use my phone lets say 15 hrs i get at least sot 7hrs and half.
Venom0642
2,361
340
83
Here's proof
Now that sot 3hrs and 40min or so at 15% when i reach at 2 or 3% my sot will be at least over 5 hrs.
anon(929436)
Getting terrible battery life on my 5 day old Note 5 - not sure if it is a defect or something else . This morning it drained about 20% in 3.5 hours with only 40 min of screen on time. Mostly on wifi at work, advanced calling enabled, running package disabler pro with xml package from the xda developers thread (i can't post links)
Tried master reset and cache wipe from bootloader. Doesn't seem to be helping. Thinking about exchanging the phone at BB to see if is a defect - looking at my usage numbers, there's no way I could get a day of use like some of you are reporting. i'm barely picking up the phone - if i use it for anything I can watch the percentage drop as I'm using it.
crf450r420
Active member
Sep 12, 2015
37
View attachment 202792View attachment 202793
Try it in safe mode for one day first. I'm finding apps are draining the battery without showing up as a power user. Mine was worse than yours and in safe mode it used a 1/6 the power.
Kelly Kearns
8,729
6
Your cell signal is probably your problem, it is almost non-existent.
Kelly Kearns
8,729
6
What are your WiFi settings? Do you have them set to scan? Always allow scanning means Google will poll your apps for location even when the apps aren't being used. If you have a low signal, it will poll forever.
Kelly Kearns
8,729
6
My Android System and OS are way up there but they don't seem to be affecting my battery. I have been doing a lot of tethering so not sure if that will make them go up like that.
Chinoo
Active member
May 19, 2010
29
uploadfromtaptalk1445706725652.jpeg something that I changed yesterday and my batter have improved so much, I turn off the WiFi when sleep, only to connect to Wifi if is connected to the power or while the phone awake, during standby mode it will help your battery
Venom0642
2,361
340
83
View attachment 202877 something that I changed yesterday and my batter have improved so much, I turn off the WiFi when sleep, only to connect to Wifi if is connected to the power or while the phone awake, during standby mode it will help your battery
Hmm i guess all phones might react differently, cause i keep my wifi always even when i go to bed and it doesn't kill my battery at all, and when I'm on 4G LTE while out house doesn't eat my battery either, so i am assuming that everyones phone react different, even though it shouldn't be that way.
xocomaox
2,279
I'm seeing very crappy numbers in here and very good numbers.
Moral of the story: Configuring Android properly is the key to good battery life.
tress
