MedicD
No I don't have a drone, or the freeflight app. And that's all I could find on google. Could it be google "play games" app?
Possibly. Check what you recently installed
as you get it?
No settings , just got bloatware disable from AT&T and Material dark theme i am running my phone normal.as you get it?
is there a setting for the signal
You also have to stop looking at "in this particular 5 mins I lost x% of battery" because you can't look at your battery life in that kind of increment and get a true picture. You have to look at the time period from fully charged and removed from the charger until it is low enough to charge again.
That could be 3 days, that could be 7 days, that could be 10 hours, that could be 5 hours. You have to look at the 100%. Sometimes you will do something on your phone and it will drop 2% in 3 minutes and then sometimes you will do something on your phone and it will take over an hours for it to drop 2%.
Here you go.. i took off my battery from charger and used it for like one hour i took some pictures after that...
And used my phone the rest of the day just to call and most of time it was unused..
The thing i noticed is it looses battery even if i dont use it.. i mean like in hour its looses 1% (can it be due to career)
These days im busy with exams coming close so i dont use phone much.. but when exams are over it'll be a hard time with battery drain
Also i took this screen at 8:17p.m so you guys think this is normal?
Then i will have to charge the phone twice a day
Also actually i would have used my phone only 2 and half hours active.. but im off to 34% from 100%
I also noticed my phone chargers up in 1:15min... its supposed to take 1:30right.. is it a problem?
About the screen shots : some are from after one hour of use. And rest is at 8pm odd
You're literally answering your own questions about battery drain. I have no idea why you're carrying on asking for help when you know what the problem isCan it be due to my carier ?
I dont have a good signal most of the time..
Hi all. I'm new here. I have 3 lines of service on Sprint. Just upgraded all three to S6 phones. I'm appalled at battery life. So I was researching the note 5. It seems to consistently get better battery? I don't quite get what the GSam Battery Monitor screen shots are telling me. How do you read that data? Thanks!
Gotta say i am very happy with my battery life on my Note 5
All i got on my AT&T Note 5 is bloatware disable and Enhanced 4G LTE services turned off and location set to mobile and wifi no tweaks at all and no not rooted either since AT&T Note 5 is locked down.What do you do to get this battery life? For example on my S6 I have lots of things turned off and power save mode turned on. Are you tweaking the phone like that? Or can I expect this battery life with the note 5 without doing all that stuff?
Make sure you turn off printing it comes on by default go to few post back i posted it cause that will also eat your battery if on.
Running On Samsung Galaxy Note 5 N920A
GSAM tells you what is using up how much of your battery. The note 5 is more efficient than the Galaxy S6 and has a bigger battery, so battery life is much better, yes. If you are able, I would recommend sending those back and getting the Note 5 or S6 edge+. I have the note 5 and my wife the edge +, her battery seems better than mine
MedicD - have you done alot to get good battery out of your note 5? Looking back through this thread it doesn't seem like you were happy with it. I eeked out about 3 hours of sot time over about 16 hours up time on my S6 yesterday. Not horrible but I found I was refraining from using it. And of course running in power save, disabled a lot of stuff and blah blah blah. . . . I literally squeaked that battery life out.
