Post your Note 5 home screen(s) below.
Please try and include any mods / launchers you use! (if possible)
Thanks .
Thanks .
What weather and clock widget is that?
Mine
http://i.imgur.com/IgHOBIF.png
Action Launcher 3 Pro, Muzei pulls my wallpaper from earthporn reddit, using Proton icon pack.
My battery life is sucking hard compared to yesterday....
Is this the stock clock and weather app running nova launcher?
Does ac3 have unread notifications yet on the icons? Moved to iPhone 6 some time ago. Im plan to comeback to Note 5.
No the app developer has no plans to implement unread notifications on the icon - and there is a link in the FAQ where he says he has no plan to do this. He explains why it doesn't make sense to him. If its a big priority for you, I'd look at some different launchers. Personally I think the reason those red numbers are so prevalent in iOS is because apple is only just now starting to make good use of the notification tray. When you can swipe down, and see the notifications there with more detail, as you can in android, having a little red number doesn't mean much. But I understand why you would want it coming from iOS. You get used to things like that.
I was asking you calico.
I might try a theme, not sure. Can you change your wallpaper with the themes, or are you stuck with the wallpaper that comes with that theme?
I'd also like to see more themes. That's one of the things I LOVED about my Palm Pre when I had it. I could download, and change themes at and moments notice if I wanted too. And I did every few days or so.
