Seeker336
I have Spigen changing stand with Samsung fast charge cables connected. This configuration worked like a champ for a long time (~9 months). Then I noticed that the LED at the bottom of hte charger would start alternating BLUE/RED/BLUE/RED and the phone would DISCHARGE overnight. This happened intermittently -- I finally just pulled the cord and connected it directly to the phone. Less convenient, but it works. After a couple days, I plugged the cable back into the Spigen charging stand and wireless charging worked as it should. After a few days, though, it would again go into discharge, with phone (Note5) turned off and 0% battery in the morning. Went back to charging directly from the cable.
On a different Spigen charging stand (same model) I placed the phone to charge while doing computer work. I noticed I did NOT get the "charging" notification, so I watched closely and saw the Battery drop about 1 % per minute while on the charging stand. Same action as with the other charging stand -- removed the Samsung cable from teh charging stand and plugged directly to the phone. Fast charge proceeded as expected.
[Scratches head.] No idea what is causing the intermittent charge or discharge behavior. Any suggestions?
