lepa71
Are you going to follow up with Samsung that their suggestion didn't work?
We all should post a review with this issue for Samsung pay.
I think I fixed it. I removed all cards from favorite cards, then tested the calendar to make sure it works. After that I re-added couple cards back and tested calendar again. It seems to work still.
Hope you can do the same.
Just from favorites, but only activate couple.
Btw I have s7.
We have a thread and working with Samsung person.
https://us.community.samsung.com/t5...cpage/board-id/GalaxyS/page/1/thread-id/23936
My wife and I are having the same issue. I turned off the lock screen and screen off features under favorite cards and it appeared to fix the issue.
Hi guys I'd like to post another potential fix. This worked for me. I use Samsung Pay, but I read that if you disable lock screen access for Samsung Pay the calendar event won't keep your screen on. I can live with unlocking my phone before I use Samsung Pay.
Here the fix: open the SP app. Tap the three little dots to go into settings. Under 'Use Favorite Cards', uncheck lock screen.
I failed to throughly test it. I'm sorry.
If the Samsung Pay is open in the background my method works.
If I force close SP then lock my phone, my method does not work.
Last Sunday night in church my pocket was Hella Hot. I didn't find out why untill I got to my car.
