Purchased today through amazon one day shipping... and I'm honestly blown away. I thought Floss Carter was being too generous at these but this is absolutely mind blowingly good.
Well I'm gonna use this for workout mostly and I don't work out more thab 1.5hours anyway..Im so tempted. how about battery...at leat 1.5 hrs for workout via bluetooth...they look amazing.Thanks.
I think gear app is required... I also noted that the main ear piece (left one for me) had worse battery life than the right one.I saw another review where they were getting like 45 minutes in one ear and an hour in another when streaming. Do you have to have the gear app installed or can you pair like regular earbuds?
Without Bluetooth, BB guy is correctThe Samsung guy at best buy said the battery life is 4 hours continuous music. I guess he was mistaken.
See, I have the dash and I haven't been too impressed with them. My first pair crapped out, and this second pair is OK but sometimes it's like they can't tell that they're in my ear. So these are much better except for the battery life?Having tried the dash first, the gear iconx are superior in fit connectivity and sound. These things don't move while running, sound decent enough and hold a connection for 20ft. Well worth 200 when everyone else charges 300.
Gear app is required to sync via Bluetooth to setup and receive calls or notifications. But when you set up music from the gear which I do it works pretty well. And the battery life does even out a bit. I think it just makes me amp up the workout if I know I only have a few hrs of juice.I think gear app is required... I also noted that the main ear piece (left one for me) had worse battery life than the right one.
The dash never fit me. The BT range was horrible and they were fussy to charge. They always drained while in the case. The Gear fit PERFECTLY at least in MY ear. I have a horrible time getting a good fit with earbuds for running but these babies work great. Battery is what it is. I usually run for an hour. Yesterday, I streamed and the battery drained about 50% . More than enough for my workout purposes which is all I will be using these for. I have noticed some battery drain while in the case after a few days. So you have to keep them charged. I wanted to like the Dash. They are sweet but they are still a work in progress.See, I have the dash and I haven't been too impressed with them. My first pair crapped out, and this second pair is OK but sometimes it's like they can't tell that they're in my ear. So these are much better except for the battery life?
