Do you have the ambient sound mode one?
Printable View
Nope I had it off. But I returned then anyway. Waiting for the airpods now...
Battery drain issue for me too. Fwiw bragi have same issue. Have to charge them before every use . Annoying.
Does anyone know of a way to pair these with another BT device such as a laptop?
You can't, can you? Requires an app to pair I think.
My left bud died but Sammy was good enough to send me a new set within a week. Really impressed with their customer service. Mine were korean versions bought off ebay before the US release and they didn't give me any trouble. I have been comparing them with the Onkyo W800BT and the Erato and these hold their own. Sound might be a little less refined but they are punchy and fun sounding which for the gym is perfect. I think Sammy knocked it out of the party with these and I would be shocked if the air pods could compete with them.
I have gone through 3 pairs.
The first pair the case stopped charging. So, I returned it and ordered another set since they were out of stock.
The second the left one died a week in and wouldn't charge.
The pair the right one stopped working after the first day.
I returned them and switched to a different style.
I love the design, the sound quality great. But, there is no reliability. There is some sort of design flaw in my opinion.
same exact battery drain issue. Charged until both leds are green and case led is also green on thursday. They sit until tuesday and I check the app and they say 10% charge and 20% charge on the buds. There is something in the manual where is these sit for an 'extended period' you should power them down but I did not consider 5 days to be 'extended period'.
I have paired these with over 4 devices FYI on the folks indicating other BT devices (computer, my samsung s7, ipad and computer). All of this was done using a typical BT pairing sequence.
They are awesome. I strictly use them/want to use them as mp3 player. For some reason, even as stand alone setting i keep getting phone calls on them. Any ideas?
https://uploads.tapatalk-cdn.com/201...5fd6962ac3.jpg
I'm reading some reviews and they confused me
My sister interested in purchasing this wearable device and asked my opinion. Anyone can give me input regarding these few points ?
1. Is it true the bluetooth connection to phone has some serious issue ? (Keep disconnecting)
2. It seems like very rarely people reviewing about the mic / phonecall at outdoor/noisy environments - comparing to standard earphone from s7 ? (This is important for her)
3. Is the over sensitive touch sensor true ?
4. Sound quality ? Some said it's ok, many said sound is too low. Which one is the truth ? (Comparing to standard samsung earphone for s7)
Apart from battery and above points, any other cons needed my concern ?
Appreciate if someone can help me and share their actual experiences
PS : would be even better if someone has ever tried airpod (as comparison base)
Thx
