Infamousx14
Yes, when it's because of software like most of battery life issues are, a software reset will certainly fix it, but if it's an app and/or a combination of an app and some settings and you do the same than the first time after the reset, it will most likely comeback.
Wipe cache Partition is done via the Recovery Menu and it's not power and volume down, is Volume up-Home-Power button.
so are you saying that this is a guessing game? i have to guess which combination of disabling apps and turning on/off random settings gives me the best battery? lol as someone who used iPhone for 8 years, i'm loving every bit of this phone except the battery problem. i think it's ridiculous.
i will try your cache method as last option, if not, i will be requesting a new phone from att.
