That's a feature of Android P. What makes you think Note 9 has it???yes I have the Kenwood 9905s which supports wireless android auto. just wasn't sure if the phone was compatible I can't find a definitive answer thru Google
Not true. I hoped up my phone to my car via Android auto. It's a note 9 on oreo.unfortunately it's not compatible yet. and who knows when we will see android P which is probably going to be our best bet for seeing it haha
We are talking about Android Auto over Bluetooth. You have Android Auto working without plugging in?Not true. I hoped up my phone to my car via Android auto. It's a note 9 on oreo.
Ok nope not via BT. Sorry!Have to double check when in the car but i believe it was working through bt
If not through Bluetooth nor wire then how do head unit & phone connect for Android Auto?to be clear I'm not talking about android auto working on your phone thru Bluetooth. I'm talking about your cars radio be able to display android auto without having the USB cable.
Looks like you are correct. And I don't think any oem car units even support it yet. Kenwood is said to have some compatible equipment. Looks like it's not going to do anything for me and my 2017 Jeep Grand Cherokee. Disappointing.it's actually done thru WiFi not Bluetooth from the research I've done.
yea I have the kenwood 9905s. it's capable. pretty annoying honestly. 1300$ phone shouldn't be limited by software haha
