How to disable bixby and bixby button SOLUTION
  • Thread starter Android Central Question
  • Start date
A
This is a solution for disabling the annoying bixby button on the note 9.
Enable Developer Options.
Scroll all the way down and click on "Background Check"
Disable Bixby Service, Bixby Voice and Voice Wake-Up
And thats it. Try to press the bixby button after that and youll get no response.
SloProjekt
6
It works.
For those that don't know how to enable developer options:
Open Settings option. Under Settings option, select About phone, then choose Software Information. Scroll down the screen and tap Build number several times until you see a message that says "Developer mode has been enabled".
monicakm
2,092
Wow, what could be going on with MY phone? Of the three services, I only have Bixby Voice. I disabled it, restarted my phone but still have Bixby Voice and the Bixby button is still active.
TabGuy
1,395
68
On my Verizon version I don't see a Bixby Service. The other two are there, though.
berfles
287
I stopped the service and it worked, but now the button is active again. Unless there's a way to kill it it forever it'll just keep starting back up again.
Mandarita
149
I did the ADB settings, too. It was working perfect. Now the button is still working, but Bixby is opening again, too. This is super annoying. It's now been my biggest issue with what would be a perfect phone. Why is Samsung forcing this issue? Why can't they just let me have control of that silly little button? I hope bxActions is able to fix it again.
sweetypie31
4,484
185
63
The package disabler app is working for me. I never had issues hitting the bixby button on my s8 , but on the n9 i was hitting it a lot.
Yguideslou
406
13
18
Package Disabler Pro... a few bucks was more than worth being able to disable a ton of unnecessary bloatware as well as kill Bixby DEAD !! LoL.
Mandarita
149
When I disable Bixby my bxActions stops working. I get a message that Bixby can't be disabled. How are you getting it to work with Bixby Voice disabled?
Yguideslou
406
13
18
If you're replying to me... I don't. I don't use BX Actions... I just don't bother with the button at all.
berfles
287
I don't even see that in the play store for the Note 9. There's no Samsung version anymore, just LG.
EDIT: Found it. Disabled Bixby stuff and button does nothing again.
kevinpleasants
687
73
28
I studied the tutorials on what Bixby is and how to use it. I'm still learning as well as Bixby is still learning my daily actions. We're both getting along well. Because I know what it is and that is not designed to be like Google Assistant and Siri that help me to understand its uses as well. Bixby is my buddy lol. Maybe if those who don't like it at first glance would take some time daily and study the tutorials you may find it's useful and by all means don't compare it to the other assistance because they aren't designed to be use in the same way. Don't let the word assistant confuse you. Go on now, go on. Give Bixby a chance.
Non
