I kinda want an option on my edge to use the s6 style edge screen function or the note edge screen function.. Do you think the functionality of the s6 edge will come to the note edge in one way or another? Or will they keep it the same and have two separate, unique devices that share the same suffix?
You already have that option on the Note Edge, the edge panel disappears when not in use. You don't have to use it, you don't even have to make it show notifications. You can remove all or most of the icons from it and disable most of the panels. although it won't hide 100% of the time, but it can be made rather useless.
We need to see how the general public, these are the millions of non-techy masses who have made Apple such a hit, react to the more expensive S6 Edge (versus the cheaper S6). If the S6 Edge takes off, then we'll see more interesting concepts, but if the public stays away from the S6 Edge, then chances are Samsung will approach it in two ways:
1) Make the cost of the S6 Edge the same as S6.
2) Drop the curved phones. Since obviously they can't be made cheap enough and the public is unwilling to pay a premium.
