- Feb 6, 2017
- 97,739
- 13,799
- 113
NiceI tried again same files but with Odin3 v3.13.1B and it worked. Success.
The version of firmware on this download site appears to be the same version that I have which was on my phone when I received it (G988USQU1ATAW). On AT&T's support site for the S20 phones, it says that G988USQU1ATBN was released on 3/4/2020. Also, after doing some more research, I found that the S20 Ultra firmware available on SamMobile is firmware version G988UOYN1ATCH which was released on 3/20/2020:
https://www.sammobile.com/samsung/galaxy-s20-ultra/firmware/#SM-G988U
But I am not sure if that will work on my AT&T locked phone. I see they list many carriers. But not AT&T. There is a version of G988UOYN1ATCH that just says USA in the Country / Carrier column though. Is the USA (no carrier identified) for version G988UOYN1ATCH a firmware that I can install on my AT&T locked S20 Ultra?
@Ruben Ocasio, do you have access to firmware G988USQU1ATBN?
Sorry for the beginner questions. This is my first time trying to use Odin and update the firmware of a Samsung phone.
Thanks!
You can download that ATCH as carrier firmware are universal , I'm not sure if Att has rolled their update out but when they do and it's different build numbers can always flash later to it , just remember to save data no factory reset use home CSC file in slot for Odin CSCThe version of firmware on this download site appears to be the same version that I have which was on my phone when I received it (G988USQU1ATAW). On AT&T's support site for the S20 phones, it says that G988USQU1ATBN was released on 3/4/2020. Also, after doing some more research, I found that the S20 Ultra firmware available on SamMobile is firmware version G988UOYN1ATCH which was released on 3/20/2020:
Thanks!
I'm sure the international should have that , but not familiar because international have many different country codesnever really went too deep into flashing firmwares on phones unless necessary, (i did it alot with blackberry though but never with samsung) is there a version of the international version, the ones without any carrier branding and bloatware??
Glad to hear thatI got ATT download files for ATCH from sammobile. Used on my unlocked ultra. Worked fine.
Anytime! , glad we could help and yes Ruben also great contributor .thanks mustang for explaining to me on my note 10 plus.how to use odin and flash.This was my first time flashing my Ultra.Thanks for always be supportive to members here.you and reubon are awesome
No problemThanks mustang7757 and Ruben for your assistance! I hope to be trying to do this later today.
No need for adb commandsI have two further questions...
1) The page that I downloaded Odin from (samsungodin.com), said that I needed to download ADB Fastboot. But in every set of directions I have seen on how to use Odin, it doesn't say what to do with ADB Fastboot and there doesn't seem to be an install for the ADB Fastboot either. Do I need to do anything with ADB Fastboot? If so, what?
2) From what I can gather, it looks like the USERDATA file is for carrier bloat and features. Is this correct? I am not sure if the latest firmware version G988UOYN1ATCH (dated 3/20/2020) which I found on SamMobile has been released by AT&T yet since the latest version I found on AT&T's support page is G988USQU1ATBN (dated 3/4/2020). Should I still go ahead and install the USERDATA file for firmware version G988UOYN1ATCH?
Thanks in advance!
