Mike Wyzlic
I spoke with Samsung technical support (Level 1 & 2) specifically about the SD slot when I was researching the GS4 before buying. This was because I had seen a lot of conflicting reports about compatibility of 64 GB cards. On the subject of Class rating, they confirmed that the SD Slot is only rated at Class 6. This supports what is mentioned above about Android limitations to Class 6. I've tried doing my own further research on Class compatibility and it seems that a higher class card will work, but just won't perform beyond the specs of the class the host device is rated for. However, I'm not an expert on SD card specifications and compatibility. Even the SD Association's website (www.sdcard.org) doesn't explain it very clearly.
Additionally, in regards to the 64 GB cards which by SD standards are all formatted as exFAT, the GS4 does support exFAT (in addition to FAT) according to the official Samsung Galaxy S4 manual as well as the Samsung Customer Consultant Guide. This was one of my main questions when I called Samsung support. This information is not found in the watered down carrier manuals for the device (Sprint's manual is horrible!). If you get a message stating that the card is formatted incorrectly for the device, beware!, you'll probably encounter problems.
I'd say a Class 6 or Class 10 card should work fine, but you might see more stability with a Class 6 card since that's what the device is 'designed' for. Also, if anyone is curious, the UHS-I specification is not supported by the GS4. This is an additional speed rating indicated by the number '1' inside a 'U' on higher end SD cards. Most 64 GB cards will have this specification in addition to the usual Class 10 speed. The SD Association isn't clear here either on compatibility, but it does seem to indicate that you should not use a UHS-I card in a device that is not UHS-I rated. So if you want to be completely trouble free (hopefully), choose a quality brand 32 GB Class 6 card (my opinion).
