I have the setting to on, and after seeing the review videos, all the places where they should work, they dont. Anybody have any ideas
Did you guys turn on the features in the sub menu?
sent with my 2 year old HTC evo3d
Does the Air Gesture icon appear in the top bar? It should be there when you are on a screen that accepts air gestures. I find in the browser I need to swipe down from the notification bar area towards the bottom of the screen to change pages.
Ok so air gestures works in browser. I was under the assumption that air gestures worked when someone called as well though. Maybe I'm wrong. I have yet to find an area on the phone where air view works.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
So how do I put this..... Ok so I did not realize there is settings located within the settings with more settings within those settings for this stuff. I just got them working. Sorry guys. Total fail lol.
I've just bought GS4 since yesterday and I found an odd problem...
When I enable the air gestures for example air jump, air move etc. none of them works.
but when I try the training section they work correctly...
even It's icon doesn't appear on the status bar, but it appears when Im trying the tutorial... and It just disappears when i go back to the menu..
Need your help on this guys..thanks!
You must use the Samsung apps..ie IE for browser; "mail" for mail , etcin order for the air gestures to work. 32GB GS4 via Android Central App
