Why is my S4 saying [system ui has stopped] ?
A
AC Question
why is my s4 saying [system ui has stopped] ?
my s4 kept saying that [there is no sim card installed please restart]... when really I had one installed so I cleared cache by holding volume up button and pressing the power button but once I cleared it I pressed restart then it said on the android figure {error}
then it restarted once It turned on again it told me [ unfortunately system UI has stopped ] please tell me how to fix the problem.
and I have also taken out the sd card and it is still happening its so frustrating because I really need my phone for work!!!!
Oliver Kelly
3
Re: why is my s4 saying [system ui has stopped] ?
Hi, please follow the steps you took to wipe your phone's cache to perform a factory reset.
Thanks.
