Can there be any downsides to using the S4 charger which has only micro USB (not micro USB3) plug? That means only the right hand side of the micro USB3 female port is used on the S5.
If i keep the original S5 charger at my desk, I need another charger by my bedside.
What might be your solution short of bringing the S5 back and forth daily?
Thanks.
Sent from my SM-G900T using AC Forums mobile app
Thanks.
