[HELP] S5 is gone?
Rekan
I have an S5 which the WiFi has gone bust, don't really care. However, after, whenever I turn on my phone, 90% of the time it fails to boot, it then reboots quickly twice with 2 vibrations, after the first vibration there is a faint white line just above half of the phones screen, on the second vibration it shows the S5 logo. It is harder to get into recovery than to actually boot the phone but download mode is not affected in any way. Is there any way to fix this?
H3aTeRzz
2,810
Hi
Thanks for the video.
It appears your phone was rooted? My only suggest I can offer you, would be to flash the original software using Odin. Goto Sammobile.com and download your OEM software, for "your specific" model number. Then flash with Odin.
It would appear that something "Might" have gone awry with Root?
helpful vidoes: https://www.youtube.com/results?search_query=unbrick+galaxy+s5
Hope this helps!
Chris
AmeliaRodriguez
