I downloaded a 3rd party weather app, removed the default Samsung weather widget from my home page, and added the 3rd party widget to my home page. As it turns out, the 3rd party app was buggy, so I removed it. I want to re-add the default S6 Edge weather widget to my home screen, but I can't find it.
I'm using Nova on ATT BTW. It seems that the widgets visible using Nova are slightly different from the widgets available using Touchwiz. Can anyone advise on how to re-add the default S6 edge weather widget? It does not show up in my list of widgets.
