To be precise its not that usb is not connecting to pc or not recognised. The usb when connected it doesn't show mtp/ptp and all it does is charge.
My friend told me that in nexus5 u can go to storage n u can enable the usb settings but on s6 edge it doesn't show that option as my s6 edge was working with out any issue before and the main problem is that i cant be sure if its a hardware problem or software as the phone displays "charger connected" notification. No mtp/ptp notification appears.even the fast charging shows only charging so wht is the problem the cable ? the fast charger ? or the s6 usb port ? but the thing is s6 for still charges so usb prob nah then cable still works as its charging but wont show mtp/ptp so is the cable of low grade ?? or is the fast charger broken if so ok i will change it but why is there a problem with the s6 edge not connecting with the pc or not recognising the otg cable it says a device has connected when u plug it in n when u disconnect it it says disconnected but wont show u data in the otg cable extension so what the hell is wrong with my mobile software hardware help me if u can plsss
and i have tried this going to dialer n *#0808# n enabling ap and usb settings n enabling the mtp + adb so i did find the usb setting option but this also doesn't work if u got the same problem n were able to fix it please help me out
