Is anyone else having volume issues with Spotify on their GS6? Today it was lower than usually while driving. And Spotify volume always drops during a notification. Is this just the app?
It's supposed to lower when you get notifications. Not sure why it would have been more quiet than usual though. Did you plug in with an AUX cable?
Quality has nothing to do with volume. You sure the cable was plugged in properly. I've never had volume issues with Spotifyyeah. I turned the car volume way up and it was definitely not as loud as it should've been. And I was playing a downloaded album at "extreme" quality, supposedly.
I use Spotify all the time, I do not have this problem
The volume goes down when I get notifications, but will go right back up
Are you using headphones? When you plug in headphones, the volume goes down and you have you turn the volume back up, thats more fore safety I believe
Does any other music service do that? Pretty sure GPM does that too. Could just put the phone on mute when you're playing musicIt was probably just a one time issue. But man I wish Spotify would just play over notifications.
Hi,
I recognize this issue. I have 2x SG6 Edge and a LG G4.
Both SG6 Edge have the volume issues. Volume goes down and come up on regular basis (no..no notifications or whatever).
My LG G4 works perfectly absolutely no such volume issues.
Doesn't take away that the SG6 Edge is a perfect device.
