Hi guys this is my first post here so please forgive me for any mistakes.
I have a white Samsung galaxy s6 32 gb and I have had it for around 2-3 weeks now and I have slight concerns about the battery life of this phone. I get around 2.5-3 SoT and that is after switching off all the unwanted settings, disabling all the unwanted apps, reducing screen brightness etc.
I have also tried pixel battery saver but that hasn't helped a lot.
Is it possible that this could be because of the lollipop memory leak issue and unwanted usage of ram because I seem to be having this problem.
Is this normal or average battery life or is it possible to get more out of this phone? Should I return it and get a new one because I have heard users getting around 5 hours SoT. Please help me out! Thanks!
i suffer no hardships doing this -
Battery Tips for Android
1. Toggle off High Accuracy GPS Mode, Bluetooth, NFC,
Hotspot/Tethering. Toggle on only as needed. (Set GPS Mode to "Battery
Saving" Mode).
2. Display Brightness - Turn off Auto Brightness and Reduce Setting
Bar to Minimum Acceptable to you.
3. Sign out of any unused Google Services like G+, Google Now, Hangouts, etc.
4. Disable Location Reporting and Location History.
5. Beware of constantly syncing in background Apps and Bloatware like
Facebook, Twitter, Weather Channel, Games, Google News/Weather,
Non-Push Email, etc. Set Sync interval for every 1 hour or more and
change settings to stop the syncing of data you don't need. Delete
their Apps and use their Web Page if acceptable.
6. Turn Off Hot Word "Hotword Detection" Always Listening Mode in
Google Search if you don't use it.
7. Turn Off Auto Camera/Photo Upload or at least set it for Upload on WIFI Only.
8. Turn Off Vibrate on Touch for Display, Keyboard, etc.
9. Turn Off Touch Sounds and Unlock Sounds.
10. Turn Off Ambient Display/Active Display Notifications if you don't need it.
11. Don't use a Live Wallpaper. Use a dark wallpaper if possible.
12. Set Display Sleep Setting to 2 Minutes or Less.
13. WIFI Settings - Advanced -
a. Network Notification - Set as OFF.
b. Scanning Always Available - Set as OFF.
c. Keep WIFI on during Sleep - Set as ALWAYS if you regularly use
WIFI. OK to keep WIFI on if you regularly use it.
14. Turn Off Always Vibrate in Gmail/Email.
15. Be careful of using too many Live Widgets and what/how often they sync.
16. Set MS Exchange Sync at 30 Days or Less if you use it.
17. Do NOT use a Task Killer App or Battery Saver App.
18. Uninstall ALL Apps that you never use. If you haven't used an
App in one month, uninstall it.
19. Reboot your phone at least once a month.
20. Wipe Cache Partition at least once a quarter or after every OS Update.
21. Consider a Factory Data Reset with a manual re-sync, manual
reinstall of all data and Apps after every major OS Letter Update.
Make sure that all of your data is first backed up to Google and
Dropbox, etc.
"I SUFFER NO HARDSHIPS DOING THIS" - this means that i personally am
giving up NOTHING with these tips. i'm not giving up any features.
there are no tradeoffs for me. a tradeoff or a hardship would be to
turn off PUSH email or use AIRPLANE mode during the day etc.
you have to find your own balance and the tips list is a start but you
must come to your own conclusion as to what's important. it's personal
preference but these are not a big deal to me at all as they do not
affect the function or operation of my phone. these tips do not
deteriorate my experience.
you don't HAVE TO do anything. the point is you if you want to
MAXIMIZE battery life you can turn things off that you aren't using.
it only makes sense. there is a FINITE amount of juice in ANY
battery. you choose how you want to spend that juice. by default most
of these devices have every feature set as ON whether you use them or
not. i prefer to change the settings in my phone to only use those
features that i personally use and need so i can maximize battery
life. i don't leave all the lights and TVs on in my house 24/7 - i
turn them on when i need them. i'm not giving anything up. my phone
does everything exactly like i want it to. i'm not missing out on
anything. it's no hardship for me. it's life. life is a delicate
balance. it's up to you to find that balance.
5-20-15
