Hi I was wondering if anyone is having the same problem I'm having my s7 seems to want to text by itself and can't get it to stop unless I turn it off. I was wondering if anyone knows how to fix this thx
You can boot into recovery mode and wipe your cache partition. If this doesn't work, you will need to do a factory reset.
