felloffthetruck
Trusted Member
I installed the Zagg HD dry and it was a piece of cake. I have used Zagg on all of my devices for quite some time and the newer dry process is much easier than the old wet one. It really is easy and it looks and feels fine.
Was you the same as the one in the above video?
let us know when you get the LUVVITT TEMPERED GLASS Screen Protector
The Zagg HD dry comes in front screen or full body option. I agree with Jneusch, it is a lot easier than their old wet application. I installed mine without any bubbles. The trick is using the squeegee in the last part when removing the film and making sure you press down both edges with your fingers several times to make sure the film adheres to the side before you remove the protected film. The one thing I wouldn't recommend you do like he did in the video is he put his fingers on the display as leverage while applying the film to the display. This will leave a fingerprint on the display as the film goes over it. If you just hold up the film and run the squeegee down the display at the same time you shouldn't need to put your fingers on your nice clean glass.
Another pointer, apply this in the bathroom after a hot steamy shower. This will cut down on dust flying about.
Obviously, your mileage will vary like everyone else. I will say the Zagg HD film is like glass and you can't even tell you have a protected film on my phone and the feel is almost identical as it being naked. It lines up perfect to the edge as well.
View attachment 221428View attachment 221429
I've had my zagg on for 3 days and it is already peeling up on the corners where it meets the case. Returning it.Any problems of it peeling up with cases?
Picked up the Zagg tempered glass today at a Zagg kiosk in a local mall. It's outstanding! Only downside is that it has black across the top and bottom. Fits perfectly and looks great. They're coming out with more colors soon - gold for sure. Also picked up the Spigen Thin fit case - works perfectly. No gapping. Glass screen protector is secure - not coming up. Highly recommend. Had the HD protector and disliked it.
Zagg glass for the edge doesn't even exist. :-\
