maf113
I don't understand if I submitted both at the same time why I'm getting one and not the other.
The way their system works, or fails to work, is each employee bungee jumps into a huge pit of claim forms and grabs as many as they can. Those are the ones that get processed that day. Each morning they repeat this ritual.
So it all depends on how your claims made it in to the pit. At the top or near the bottom or in your case one of each.
This explanation makes as much sense as anything Prize logic will tell you. They don't know how the system works either.
