Follow up to an earlier thread. I have a SanDisk 64GB SD card that suddenly (in past few weeks?) stopped working, although I only recognized this the other day. The phone recognizes that I have an SD card, but I can't do anything with it - meaning I'm not getting the 'notification' errors that are in other threads.
In the S7, here is the situation:
1) The card is *not* the problem - I inserted it into my old S5 and was able to view photos and transfer apps to it.
2) Per a recommendation in other thread, SD Insight says it is a true SanDisk 64 card
3) In ES file explorer, the SD card is recognized, and even can analyze the card. But what is returned is basically a graph that shows that 45% of card is used by "other" file types (26.85GB, which is probably accurate), and photos/audio/video etc are all at 0.00 Bytes
4) All of my photos have disappeared when I look in Gallery - except for any photos/videos taken in past 3 weeks (?!?). However, pretty sure that these for some reason were suddenly being saved to device even though I never directly changed any settings. Perhaps it was 3 weeks ago the card "failed". Note that all photos on card can be viewed when I insert card into my S5
5) I've installed/uninstalled card multiple times to make sure it's laying correctly in tray
Any thoughts?
Any thoughts?
