Hello-
I recently picked up a Verizon S7 edge on the most recent update (April patch and nougat). I have the hotspot option as a quick toggle in the drop down quick settings panel. When I select the mobile hotspot toggle from the lock screen (power button, screen still locked), it unlocks the phone to "check the subscription" and turn on the hotspot. Does anyone else have this issue? Has anyone else found that other quick toggles in the quick settings panel will unlock the phone and bypass the security feature?
Thank you!
Thank you!
