Jadaress1
What I have done, and it's seemed to have worked, is go through all the processes suggested in the forum but not changed any settings. I've turned some of the options on, but then turned them back off and vice versa. It's like I've jogged the memory of the phone so to speak. Hope it helps!
Can I ask if you have the spam caller protection in your settings? If so is it On and you consistently getting all your missed call notifications now? Cause no matter what I do with that service on it doesn't consistently show me my missed calls. I try all these fixes and think it's fixed but happens again. I need the fix to be 100 percent and not just intermittent like it is right now with that option on. Its really annoying cause I used that service on all my other Samsung phones with no problem. First time I've faced this issue. Thanks.
