so after a week. I'm getting better battery life. I turned off the always option on the heart rate sensor and turned off the cycling and rowing auto workout detect and battery life has improved to just about how it was before Tizen 3.01
Make sure your not on an unlocked device. Vzw had to add hd calling and wifi crap to get mine to work properly. As long as everything is right on their end it works. If one is off it quits working for some reason.Saga continues Performed thee total Factory resets per VZW techs and multiple check this setting and this setting. I am only able to run the watch in Bluetooth or StandAlone mode. Cannot Remotely Connect anymore.
VZW says sorry we have done all we can call Samsung.......
Samsung wants to know if there is any physical or water damage. I keep telling them that the watch worked perfect until the upgrade
Samsung wants me to send in the watch for "repair". No love no watch for who knows how long. UGH!!
Wow! Mine is a 48% after 15hrs of use.
I got my Gear S3 back from Samsung. Although it was sent to warranty repair because I could no longer get a remote connection the returned back the following with the watch.
PROBLEM Found: Will not Charge - Internal Battery Failure
Solution: Warranty, Replace Part.
Incell Battery Pack
SVC PBA-MAIN(VZW)
SO......I get it back power it up and and it won;t activate on VZW LTE. spent a couple hours with three different techs, 4 factory resets, numerous power recycle and my adamant refusal to factory reset my note 8!! LOL.
Then out of frustration I started to confirm the IMID and the ICCID #'s on my account with the one in the watch. Turns out the ICCID on the watch was one number off from what the VZW account had LOL!!!
Tech changed the ICCID# to match. Activated right away.
Tizen OS loaded up, remotely connects and bluetooth connects back and forth without a hitch now.
BAttery life also seems to be even better than before.
Hopefully this brief happiness will last a while
