Samsung Moment FAQ's (Updated 2/5) Please Read Before Posting
Status
Not open for further replies.
Cory Streater
9,490
3,428
The following are frequently asked questions within the Samsung Moment forum. This page will be updated frequently, and suggestions are welcomed. Please PM me if you have a suggestion or would like to add additional content.
Documentation:
1. FAQ's, user guides tips/tricks, and software updates for the Moment on Sprint's product support page.
How to:
1. Perform a hard reset: Menu>Settings>SD card & phone storage>then scroll to the bottom and Factory data reset.
Known/Common Issues:
1. Battery life.
2. GPS inaccurate.
3. Overheating.
4. CL14 1x/EV issues.
5. Issues fixed in CL14 software update on 1/15/2010:
  • Network Assist GPS to allow indoor location fix
  • Updates to several third-party apps, including Visual Voicemail, NFL, NASCAR and Sprint TV
  • Change to Emergency Dial on lock screen
  • Hard reset available in recovery mode: remove and reinsert battery; press volume down, send and end keys until reboot option pops up; scroll to wipe data/factory reset; press OK
  • Various improvements to battery life
Random:
1. Get your Google Wave invite here.
2. Get your Google Voice invite here.
3. Syncing with iTunes solution: doubleTwist
4. Wallpapers and Ringtones
If you do not see an answer to your question above, please use the SEARCH feature of the forums, to look for a solution, before starting a new thread.
Reactions: davecttt
Status
drayb
