xtibi
Did you find a way to permanently turn off the wifi powersave mode? Thanks.
If you turn on wifi power save mode your wifi internet connection speed will be very slow. Like in my case I have a 15 mbps internet plan but using the speedtest.net app on my phone the speed is only 1.5mbps. But after turning off the wifi power save mode I get a 15mbps connection.
My question is, is there a way to permanently turn off the wifi powersave mode? It's really annoying I always need to do the *#0011# sequence everyday!
I think it automatically turns on when you get a low battery or if you restart your phone.
360 Virtual Tourist - 360? Virtual Tours, Panoramic Photography, Timelapse Videos
