is there a way to wipe the system beside the factory reset... i do the factory rest and its not wiping it.
thanks
thanks
it seems not to be working, i hold the volume down then press the power... nothing happens.
- Turn the power off. If your Nexus S is frozen, pull the battery out and reinsert it
- Hold the Volume Down button
- Press and release the Power button
- You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
- Select Clear Storage by pressing the Volume Down button
- Now simply confirm your decision: Volume Up for YES and Volume Down for NO
This should delete all data on your phone. Be sure to back up the information you don't want to lose.
Please let me know if this works.
