which of the following verizon phones plays better on the tmobile netwrok?
1. HTC - One (M8) 4G LTE
2. LG - G3 4G LTE
2. LG - G3 4G LTE
Verizon won't work...it's CDMA and only uses the Sim card for lte data, sorry others have lied to you
The Sim card is only used for lte data ( gsm)....voice is on the CDMA portion.
The Verizon Samsung Galaxy Note 4 will not support simultaneous voice and data over 4GLTE on tmo. The Verizon Samsung Galaxy Note 4 doesn't currently support volte.You're soooo very correct... I have a Galaxy Note 4 that I just transferred from Verizon to T-Mobile and so far I'm able to use it in every way except one. When I make a phone call the 4G LTE/H+/H/E data disables immediately preventing me from surfing the internet and using apps until the call has ended. This is frustrating and I've been looking for a solution but I've been coming up empty. Do you have any suggetstions for a fix Ambassador?
Yet setting the network mode to gsm/utms. It might support simultaneous voice and data there, assuming Verizon didn't disable it.
Sent from my Samsung Galaxy Tab Pro 8.4
